I am trying to produce a workflow to determine the ground state magnetic ordering of a structure. I am getting an error about unexpected keyword args. For other workflows I have mostly relied on presets from vasp.workflows.presets
so maybe I’m not actually using the MagneticOrderingsWF
class correctly at all. I would expect the following to return a Fireworks Workflow. Full traceback (making use of stackprinter):
[1]: struct
[1]: Structure Summary
Lattice
abc : 3.15302065 3.15302065 5.12425282
angles : 90.0 90.0 119.99999999999999
volume : 44.117897832868465
B : -1.5765103249999994 2.730595981556924 1.9306683233340037e-16
C : 0.0 0.0 5.12425282
PeriodicSite: Li (0.0000, 1.8204, 3.2925) [0.3333, 0.6667, 0.6425]
PeriodicSite: Li (1.5765, 0.9102, 1.8318) [0.6667, 0.3333, 0.3575]
PeriodicSite: Co (0.0000, 0.0000, 0.0000) [0.0000, 0.0000, 0.0000]
PeriodicSite: O (0.0000, 1.8204, 1.2151) [0.3333, 0.6667, 0.2371]
PeriodicSite: O (1.5765, 0.9102, 3.9092) [0.6667, 0.3333, 0.7629]
[2]: MOWF = MagneticOrderingsWF(struct)
orig_wf = MOWF.get_wf()
File /Users/dan/anaconda3/lib/python3.6/site-packages/IPython/core/interactiveshell.py, line 2963, in run_code
exec(code_obj, self.user_global_ns, self.user_ns)
File <ipython-input-9-625e53ec6470>, line 2, in <module>
1 MOWF = MagneticOrderingsWF(struct)
--> 2 orig_wf = MOWF.get_wf()
MOWF = <atomate.vasp.workflows.base.magnetism.MagneticOrderingsWF o
bject at 0x1c1e0d4940>
MagneticOrderingsWF = <class 'atomate.vasp.workflows.base.magnetism.MagneticOrderi
ngsWF'>
struct = Structure Summary
Lattice
340037e-16
.6425]
.3575]
.0000]
PeriodicSite:...
MOWF.get_wf = <method 'MagneticOrderingsWF.get_wf' of <atomate.vasp.workfl
ows.base.magnetism.MagneticOrderingsWF object at 0x1c1e0d494
0> magnetism.py:201>
File /Users/dan/anaconda3/lib/python3.6/site-packages/atomate/vasp/workflows/base/magnetism.py, line 346, in get_wf
201 def get_wf(
202 self, scan=False, perform_bader=True, num_orderings_hard_limit=16, c=None
203 ):
342 parent_structure=self.sanitized_structure,
343 origins=ordered_structure_origins,
344 input_index=self.input_index,
345 perform_bader=perform_bader,
--> 346 scan=scan,
347 ),
self = <atomate.vasp.workflows.base.magnetism.MagneticOrderingsWF o
scan = False
perform_bader = True
num_orderings_hard_limit = 16
c = {'VASP_CMD': '>>vasp_cmd<<',
'DB_FILE': '>>db_file<<',
'user_incar_settings': {'ISYM': 0,
'LASPH': True,
'EDIFFG': -0.05}}
self.sanitized_structure = Structure Summary
Lattice
340037e-16
.6425]
.3575]
.0000]
PeriodicSite:...
ordered_structure_origins = ['fm', 'afm', 'afm', 'afm', 'afm', 'afm', 'afm', 'afm', 'afm
', 'afm', 'afm', 'afm', ]
self.input_index = None
File /Users/dan/anaconda3/lib/python3.6/site-packages/fireworks/core/firework.py, line 70, in __init__
57 def __init__(self, *args, **kwargs):
66 if self.optional_params is not None:
67 allowed_params = required_params + self.optional_params
68 for k in kwargs:
69 if k not in allowed_params:
--> 70 raise RuntimeError("Invalid keyword argument specified for: {}. You specified: {}. Allowed values are: {}.".format(self.__class__, k, allowed_params))
self = MagneticOrderingsToDB
{'db_file': '>>db_file<<',
'wf_uuid': 'be373e28-0d83-495f-835b-46f27135bc3a',
'auto_generated': False,
'name': 'MagneticOrderingsToDB',
'parent_structure': Structure Summary
Lattice
282
0037e-16
B...
args = ()
kwargs = {'db_file': '>>db_file<<',
Lattice
282
0037e-16
B : -1.5765103249999994...
self.optional_params = ['origins', 'input_index', ]
allowed_params = ['db_file', 'wf_uuid', 'parent_structure', 'perform_bader',
'scan', 'origins', 'input_index', ]
required_params = ['db_file', 'wf_uuid', 'parent_structure', 'perform_bader',
'scan', ]
k = 'auto_generated'
self.__class__ = <class 'atomate.vasp.firetasks.parse_outputs.MagneticOrderin
gsToDB'>
---- (full traceback above) ----
scan=scan,
RuntimeError: Invalid keyword argument specified for: <class 'atomate.vasp.firetasks.parse_outputs.MagneticOrderingsToDB'>. You specified: auto_generated. Allowed values are: ['db_file', 'wf_uuid', 'parent_structure', 'perform_bader', 'scan', 'origins', 'input_index'].
I assume that ‘auto_generated’ and ‘name’ should be allowed as they look to be set to sensible values?
A : 3.15302065 0.0 1.9306683233340037e-16
