Firstly, thank you for providing the excellent software Fireworks Free and OpenSource.
There is an issue with the append_wf
feature, I am getting the error:
Workflow object: (fw_ids: [-1 ] , name: unnamed WF)
File "initModels", line 55, in <module>
initWfs.append_wf(m.initialisationStrategy().workflow(m), initWfs.root_fw_ids)
File "/home/sigveka/.local/lib/python2.7/site-packages/fireworks/core/firework.py", line 944, in append_wf
updated_ids = self.refresh(new_fw.fw_id, set(updated_ids))
File "/home/sigveka/.local/lib/python2.7/site-packages/fireworks/core/firework.py", line 980, in refresh
if self.fw_states[parent] not in completed_parent_states:
KeyError: -5
The issue is in the file core/firework.py
in a block of the refresh
method starting approximately on line 977:
# check parent states for any that are not completed
for parent in self.links.parent_links.get(fw_id, []):
m_state = 'WAITING'
break
I fixed the issue temporarily as follows:
if self.id_fw[parent].state not in completed_parent_states: # <----- BUGFIX: used to be 'self.fw_states[parent]' instead of 'self.id_fw[parent].state'
m_state = 'WAITING'
break
However, knowing the inner workings of the library you may have a more elegant fix.
Regards,
Sigve Karolius
Hi Sigve,
Thank you for the report. What you wrote should work, however, the performance on large workflows (e.g. hundreds of Fireworks) will be much worse.
I was trying to reproduce the error but could not. For example, I tried the below:
from fireworks import Firework, Workflow, FWorker, LaunchPad, ScriptTask
from fireworks.core.rocket_launcher import rapidfire
# set up the LaunchPad and reset it
launchpad = LaunchPad()
launchpad.reset('', require_password=False)
# define four individual FireWorks used in the Workflow
task1 = ScriptTask.from_str('echo "Ingrid is the CEO."')
task2 = ScriptTask.from_str('echo "Jill is a manager."')
task3 = ScriptTask.from_str('echo "Jack is a manager."')
task4 = ScriptTask.from_str('echo "Kip is an intern."')
fw1 = Firework(task1)
fw2 = Firework(task2)
fw3 = Firework(task3)
fw4 = Firework(task4)
fw5 = Firework(task1)
fw6 = Firework(task2)
fw7 = Firework(task3)
fw8 = Firework(task4)
# assemble Workflow from FireWorks and their connections by id
workflow = Workflow([fw1, fw2, fw3, fw4], {fw1: [fw2, fw3], fw2: [fw4], fw3: [fw4]})
launchpad.add_wf(workflow)
workflow2 = Workflow([fw5, fw6, fw7, fw8], {fw5: [fw6, fw7], fw6: [fw8], fw7: [fw8]})
launchpad.append_wf(workflow2, [1])
Do you by any chance have a sample code I can run to reproduce the error?
Anubhav
initWfs.append_wf(m.initialisationStrategy(). workflow(m), initWfs.root_fw_ids)
KeyError: -5
for parent in self.links.parent_links.get( fw_id, []):
m_state = 'WAITING'
break
m_state = 'WAITING'
break
Regards,
Sigve Karolius
(please note that the code snippet I wrote will reset a local database of <25 workflows, so please check before executing)
On Friday, September 7, 2018 at 4:19:17 PM UTC-7, Anubhav Jain wrote:
Hi Sigve,
Anubhav
KeyError: -5
m_state = 'WAITING'
break
m_state = 'WAITING'
break
Regards,
Sigve Karolius
