Hi! For some reason, I’m having some real trouble connecting FireWorks to my MongoDB Altas cluster.
Here’s what I’ve done:
I successfully completed the ‘Testing connection to a remote server’ section on the fireworks installation page.
Next, I ran
lpad init
which created the file my_launchpad.yaml
In this file, I have the following:
authsource: research
host: mongodb+srv://chenge:<password>@research-nwvup.mongodb.net/test?retryWrites=true&w=majority
logdir: null
password: <password>
port: 27017
ssl: false
ssl_ca_certs: null
ssl_certfile: null
ssl_keyfile: null
ssl_pem_passphrase: null
strm_lvl: INFO
uri_mode: false
user_indices: []
username: chenge
wf_user_indices: []
My Mongo cluster is called “research”, and my username is chenge.
When I run the suggested command
lpad add_scripts 'echo "hello"' 'echo "goodbye"' -n hello goodbye -w test_workflow
I get the following error:
login1(1044)$ lpad add_scripts 'echo "hello"' 'echo "goodbye"' -n hello goodbye -w test_workflow
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/fireworks/core/launchpad.py", line 1377, in get_new_fw_id
return self.fw_id_assigner.find_one_and_update({}, {'$inc': {'next_fw_id': quantity}})['next_fw_id']
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/pymongo/collection.py", line 3136, in find_one_and_update
array_filters, session=session, **kwargs)
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/pymongo/collection.py", line 2885, in __find_and_modify
write_concern.acknowledged, _find_and_modify, session)
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/pymongo/mongo_client.py", line 1491, in _retryable_write
with self._tmp_session(session) as s:
File "/opt/apps/intel18/python3/3.7.0/lib/python3.7/contextlib.py", line 112, in __enter__
return next(self.gen)
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/pymongo/mongo_client.py", line 1820, in _tmp_session
s = self._ensure_session(session)
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/pymongo/mongo_client.py", line 1807, in _ensure_session
return self.__start_session(True, causal_consistency=False)
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/pymongo/mongo_client.py", line 1760, in __start_session
server_session = self._get_server_session()
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/pymongo/mongo_client.py", line 1793, in _get_server_session
return self._topology.get_server_session()
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/pymongo/topology.py", line 482, in get_server_session
None)
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/pymongo/topology.py", line 205, in _select_servers_loop
self._error_message(selector))
pymongo.errors.ServerSelectionTimeoutError: connection closed,connection closed,connection closed
During handling of the above exception, another exception occurred:
File "/home1/05778/chenge/.local/bin/lpad", line 11, in <module>
load_entry_point('FireWorks==1.9.4', 'console_scripts', 'lpad')()
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/fireworks/scripts/lpad_run.py", line 1176, in lpad
args.func(args)
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/fireworks/scripts/lpad_run.py", line 579, in add_scripts
lp.add_wf(Workflow(fws, links, args.wf_name))
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/fireworks/core/launchpad.py", line 349, in add_wf
old_new = self._upsert_fws(list(wf.id_fw.values()), reassign_all=reassign_all)
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/fireworks/core/launchpad.py", line 1412, in _upsert_fws
first_new_id = self.get_new_fw_id(quantity=len(fws))
File "/home1/05778/chenge/.local/lib/python3.7/site-packages/fireworks/core/launchpad.py", line 1379, in get_new_fw_id
raise ValueError("Could not get next FW id! If you have not yet initialized the database,"
ValueError: Could not get next FW id! If you have not yet initialized the database, please do so by performing a database reset (e.g., lpad reset)
Google searches have not gotten me anywhere, as the two results are 1) source code for FireWorks, and 2) some other package for which I have no idea what their setup is.
Could someone help me out on this? Thanks in advance!
