I am getting an error (attached below) after installing and running the “python setup.py test”. The tests seems to have passed but some error shows up after the ‘OK’.
I have Fireworks 1.9.0 and Rocketsled 2019.6.5
Thanks.
Nitin
ok
test_Dtypes (rocketsled.tests.test_utils.TestUtilities) … ok
test_check_dims (rocketsled.tests.test_utils.TestUtilities) … ok
test_convert_native (rocketsled.tests.test_utils.TestUtilities) … ok
test_convert_value_to_native (rocketsled.tests.test_utils.TestUtilities) … ok
test_deserialize (rocketsled.tests.test_utils.TestUtilities) … ok
test_get_default_opttask_kwargs (rocketsled.tests.test_utils.TestUtilities) … ok
test_get_len (rocketsled.tests.test_utils.TestUtilities) … ok
test_is_discrete (rocketsled.tests.test_utils.TestUtilities) … ok
test_latex_float (rocketsled.tests.test_utils.TestUtilities) … ok
test_pareto (rocketsled.tests.test_utils.TestUtilities) … ok
test_random_guess (rocketsled.tests.test_utils.TestUtilities) … ok
test_serialize (rocketsled.tests.test_utils.TestUtilities) … ok
test_split_xz (rocketsled.tests.test_utils.TestUtilities) … ok
test_tolerance_check (rocketsled.tests.test_utils.TestUtilities) … ok
Ran 24 tests in 31.021s
OK
Error in atexit._run_exitfuncs:
File “”, line 983, in _find_and_load
File “”, line 953, in _find_and_load_unlocked
File “”, line 219, in _call_with_frames_removed
File “/home/nkumar/.conda-envs/Adapt/lib/python3.7/site-packages/sklearn/init.py”, line 64, in
from .base import clone
File “/home/nkumar/.conda-envs/Adapt/lib/python3.7/site-packages/sklearn/base.py”, line 11, in
import numpy as np
File “/home/nkumar/.conda-envs/Adapt/lib/python3.7/site-packages/numpy/init.py”, line 142, in
from . import core
File “/home/nkumar/.conda-envs/Adapt/lib/python3.7/site-packages/numpy/core/init.py”, line 40, in
from . import multiarray
File “/home/nkumar/.conda-envs/Adapt/lib/python3.7/site-packages/numpy/core/multiarray.py”, line 12, in
from . import overrides
File “/home/nkumar/.conda-envs/Adapt/lib/python3.7/site-packages/numpy/core/overrides.py”, line 46, in
RuntimeError: implement_array_function method already has a docstring
import numpy as np
from . import core
import numpy as np
from . import core
import numpy as np
from . import core
import numpy as np
from . import core
import numpy as np
from . import core
