To whom it may concern,
I am trying to install atomate, pymatgen, fireworks, and custodian on stampede2. When I read their manual to install (ppt file in atomate-config-templates), I found that it suggest python/2.7 rather than python3 because Python3 is not compatible with VASP on Stampede.
I wonder if Python3 is not compatible with VASP on “Stampede2”.
Thank you for your help.
Sooran Kim
I think Brandon wrote those instructions (?) and would need to clarify here.
Sooran Kim
Thank you for your reply.
The instructions are
Login to Stampede if you have not already
First, add loading Python and VASP to your .bashrc
$ vi ~/.bashrc
your other .bashrc stuff here
module load python/2.7.12
module load vasp/5.4.1
Normally, I would suggest Python3, but Python3 is not compatible with VASP on Stampede (incompatible compilers)
Load your .bashrc with the changes we just made.
$ source ~/.bashrc
Both of these commands should then give you output
$ which vasp_std
$ which python
I wonder the compatibility issue is still applied on Stampede2.
2017년 8월 17일 목요일 오후 12시 48분 42초 UTC-4, Anubhav Jain 님의 말:
Sooran Kim
Hi Sooran,
I indeed made those slides. The slides themselves are a little out of date for Stampede 2, but the script should work, in principle, if you follow the instructions in the README.
We are currently working on a better installer, which you can track the progress of on GitHub issue 149, that will take the place of this basic installation script.
Brandon
$ vi ~/.bashrc
$ source ~/.bashrc
$ which vasp_std
$ which python
Sooran Kim
Hi Brandon,
I’m still confused that Can I use python3/3.6.1 when I install atomate on Stampede2?
Or should I follow the slide and use python/2.7.13 on Stampede2?
Sooran
2017년 8월 17일 목요일 오후 1시 45분 10초 UTC-4, Brandon B 님의 말:
Hi Sooran,
Brandon
$ vi ~/.bashrc
$ source ~/.bashrc
$ which vasp_std
$ which python
Sooran Kim
Atomate supports python 3.6 and 2.7. Those slides were originally written for when Stampede did not support Python 3.
If Stampede2 is supporting Python 3, I would recommend using that.
Brandon
On Thursday, August 17, 2017 at 2:28:21 PM UTC-4, [email protected] wrote:
Hi Brandon,
Sooran
Hi Sooran,
Brandon
$ vi ~/.bashrc
$ source ~/.bashrc
$ which vasp_std
$ which python
Sooran Kim
