Dear Atomate Team
I’ve encountered some difficulty customizing a the atomate.vasp.fireworks.core.LepsFW to output more information into the task document than the default.
In the original firework, the LepsFW terminates after generating a task document in MongoDB that reports the following fields in the output taskdoc: epsilon_static, epsilon_static_wolfe, epsilon_ionic, piezo_ionic_tensor, piezo_tensor. However, since the DFPT calculation generates other information in calcs_reversed/output section as well, such as force_constants, normalmode_eigenvals etc, I want to customize the firework to report these information in the output taskdoc too.
May I know what is the cleanest way of doing this?
What I have tried is the following:
The Original LepsFW parses the vasp output to MongoDB tasks collection using the atomate.vasp.firetasks.parse_output.VaspToDb, which in turn invokes the atomate.vasp.drones.VaspDrone to do the actual parsing. I made copies of
atomate/vasp/firework/core.py
atomate/vasp/firetasks/parse_outputs.py
atomate/vasp/drones.py
in my own user directory in a folder named “custom” and inserted a sys.path.append command in both core.py and parse_output.py so that the modified files load each of their subsidiary from -
custom.atomate.vasp.firetasks.parse_output.VaspToDb
custom.vasp.drones.VaspDrone
The modified drones.py’s line 299 is then edited to include terms such as “force_constants” etc. so that they will be parsed to the “output” taskdoc.
I thought this will be sufficient but the following error popped up:
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 1461, in _refresh_wf
updated_ids = wf.refresh(fw_id)
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/core/firework.py”, line 1005, in refresh
updated_ids = updated_ids.union(self.apply_action(m_action, fw.fw_id))
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/core/firework.py”, line 813, in apply_action
apply_mod(mod, self.id_fw[cfid].spec)
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 1765, in spec
return self.partial_fw.spec
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 1838, in partial_fw
self._fw = Firework.from_dict(data)
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/utilities/fw_serializers.py”, line 155, in _decorator
new_args[0] = {k: _recursive_load(v) for k, v in args[0].items()}
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/utilities/fw_serializers.py”, line 118, in _recursive_load
return {k: _recursive_load(v) for k, v in obj.items()}
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/utilities/fw_serializers.py”, line 121, in _recursive_load
return [_recursive_load(v) for v in obj]
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/utilities/fw_serializers.py”, line 113, in _recursive_load
return load_object(obj)
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/utilities/fw_serializers.py”, line 329, in load_object
mod = import(modname, globals(), locals(), [classname], 0)
ModuleNotFoundError: No module named ‘custom’
During handling of the above exception, another exception occurred:
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/core/rocket.py”, line 357, in run
lp.complete_launch(launch_id, m_action, final_state)
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 1272, in complete_launch
self._refresh_wf(fw_id)
File “/opt/apps/util/easybuild/software/atomate/0.8.4-intel-2018b-Python-3.6.6/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 1476, in _refresh_wf
raise RuntimeError(err_message)
RuntimeError: Error refreshing workflow. The full stack trace is: Traceback (most recent call last):
It seems that there are more files and classes involved even after drones.py; however, I am unable to locate them. At this point, the process starts to look very complicated.
May I know if there is a cleaner way of achieving this objective? Or if not, which other files should I modify to overcome this error?
Best wishes
Yaze
p.s.
I’ve tried modifying task_materials.py in atomate/vasp/builder to parse the sections in “calcs_reversed”, but it seems that the “calcs_reversed” is a list with only 1 element. I can only parse the entire “calcs_reversed” to a new taskdoc but am unable to parse only a section of it. Testing with adding the following line
doc[“testing”] = taskdoc[“calcs_reversed”][1]
to task_materials.py leads to IndexError: list index out of range
