Hello Jae,
Glad you got it worked out.
For what it’s worth, I usually employ conda to install the latest version of pymatgen before installing matminer on my Windows computer:
conda install -c matsci pymatgen
pip install matminer
This will install all of the libraries that require VS Build Tools (e.g., pyspglib) with conda so that you do not need to install them with pip.
Logan
Sent: Friday, September 13, 2019 5:53 PM
To: matminer
Subject: Re: Matminer Taken Down from Conda-Forge
VS Build Tools solved the problem.
On Friday, September 13, 2019 at 4:29:48 PM UTC-4, Jason Hattrick-Simpers wrote:
Is there any plan to put Matminer back up on Conda-Forge? For some reason pip install matminer doesn’t work on my windows build. It is failing to build pymatgen, which is odd since it is already on my system.
You received this message because you are subscribed to the Google Groups “matminer” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/matminer/986f9c85-b6a1-4e46-8097-03cb8f610b39%40googlegroups.com.
Hey Logan,
I used those commands in that order and kept getting an error.
I had to install VSBuild separately and then everything went smoothly. Not sure if that is a nuance of the security on my computer, the version of windows/Anaconda I use, or just the normal way things should proceed.
Once VSBuild Tools was installed everything went smoothly.
Jae
On Behalf Of Logan Ward
Sent: Monday, September 16, 2019 3:50 PM
To: [email protected]; matminer [email protected]
Subject: RE: Matminer Taken Down from Conda-Forge
Hello Jae,
Logan
To: matminer
[email protected].
[email protected].
https://groups.google.com/d/msgid/matminer/5d7fe765.1c69fb81.34023.0e5d%40mx.google.com.
