This is a very similar question to one already posted but basically getting xgboost in windows with anaconda is quite difficult. Anaconda for windows currently only supports py-xgboost:
https://anaconda.org/anaconda/py-xgboost
or I can hack getting xgboost on my computer in windows but only version 82:
https://medium.com/@rakshithvasudev/how-i-installed-xgboost-after-a-lot-of-hassels-on-my-windows-machine-c53e972e801e
Is it hard to add support for either of these two packages instead of xgboost 72.1? Or are there any workarounds I can try?
Thanks so much!
Emily Schueller
I just went into the requirements.txt and changed the version of xgboost to 0.80 (I guess version 82 installs as 80) and the rest of the install went fine - I successfully imported automatminer into a script. I probably haven’t used the part that calls xgboost yet so I’ll let you know if it seems like that was a problem!
Thank you!
Emily S
Thanks so much!
Emily Schueller
Great! Glad you got it worked out, and thanks for sending us the solution!
Logan
Sent: Wednesday, May 8, 2019 8:31 PM
To: matminer
Subject: Re: Installing automatminer with Windows with Anaconda
Thank you!
Emily S
Thanks so much!
Emily Schueller
You received this message because you are subscribed to the Google Groups “matminer” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
To view this discussion on the web visit https://groups.google.com/d/msgid/matminer/7ee8164d-87e6-4d89-9832-594240aaf2b5%40googlegroups.com.
For more options, visit https://groups.google.com/d/optout.
Hey Emily,
Thank you for reporting this bug. I will add a todo to update the xgboost version to 0.80 to help our Windows-based users out for upcoming releases.
Alex
Thank you!
Emily S
Thanks so much!
Emily Schueller
