I was using the elastic workflow to get elastic constants. I successfully run the workflow for graphene, MoS2 and WSe2, and I used the following script to read shear and bulk moduli:
from
atomate.utils.utils import get_database
from
pymatgen import Structure
from
pymatgen.analysis.elasticity.elastic import ElasticTensor
The values I got for graphene is the same as what I had by doing calculations manually and performing a fit, but the values for MoS2 is very off. I am suspecting that the units are not consistent. I wonder what the unit the output is? I couldn’t find anything in the documentation. Thanks in advance for your help!
Research Scientist, Accelerated Materials Design and Discovery
TOYOTA** ****Research **Institute
from
from
from
Zoe
You received this message because you are subscribed to the Google Groups “atomate” group.
To unsubscribe from this group and stop receiving emails from it, send an email to [email protected].
Confidential or protected information may be contained in this email and/or attachment. Unless otherwise marked, all TRI email communications are considered “PROTECTED” and should not be shared or distributed. Thank you.
Thanks for your response. But does this unit make sense for 2D materials? GPa can be converted to eV/A^3, but how does it convert to eV/A^2 for a 2D material?
Zoe Zhu
On Tuesday, July 2, 2019 at 3:39:48 PM UTC-4, Joseph Montoya wrote:
The units should be GPa.
Joseph Montoya, PhD
from
from
from
Zoe
