Having an issue with the compatibility of a compound that I haven’t resolved yet which I figured I’d raise while I continue working on it.
mp-26689’s document shows {“is_compatible”: True}, but when trying to process it using MaterialsProjectCompatibility throws a CompatibilityError, here’s a MWE:
from pymatgen import MPRester
from pymatgen.entries.compatibility import MaterialsProjectCompatibility
from pymatgen.entries.computed_entries import ComputedEntry
# Fetch data
props = ["run_type", "is_hubbard", "pseudo_potential", "elements",
"hubbards", "potcar_symbols", "oxide_type", "chemsys", "is_compatible",
"energy", "unit_cell_formula", "task_id", "pretty_formula"]
with MPRester() as mpr:
data = mpr.query({"task_id": "mp-26689"}, props)[0]
assert data['is_compatible']
# Construct computed entry with params
data["potcar_symbols"] = [
"%s %s" % (data["pseudo_potential"]["functional"], l)
for l in data["pseudo_potential"]["labels"]]
ce_data = {"oxide_type": data["oxide_type"]}
entry = ComputedEntry(
data["unit_cell_formula"], data["energy"], parameters=data,
data=data, entry_id=data["task_id"])
# Try processing compatibility
compat = MaterialsProjectCompatibility()
# This raises CompatibilityError because U on O is 3.25
compat.get_corrections_dict(entry)
